I Have a KDL46W905A TV and can not get it to recognise my Laptop through a bluetooth connection.
I have checked that the software has been updated on the TV which it tells me is the most current download.
The laptop recognises the TV and gives me a code of numbers that should appear on the TV but the TV can not find any other hardware not even my mobile.
Is this a common problem does anyone have a solution?
Hi there
You can only connect a mouse to the TV using bluetooth, hence the reason why you cannot via bluetooth to the laptop.
More information in the manual:
http://pdf.crse.com/manuals/13HG900111/EN/c_gset_bluetooth.html
Hi there
