Hey all,
Does anyone know if Sony will be supporting the iPlayer UHD trial on the KD-55x8505b?
Cheers,
Derek
Hi there
It looks like some Panasonic models are the first to get the trial:
http://iplayerhelp.external.bbc.co.uk/tv/planet_earth_4k
BBC might be doing a phased trial roll-out (just a guess), so in time more brands and models "should" be added.
I understand participation in the trial depends on whether the TV can support an emerging standard for HDR encoding called Hybrid Log-Gamma (HLG). I know the TV doesn't support this standard at present, but I wonder (hope) if it's just a matter of a firmware update.
Hi there
Unfortunately 2014 TVs such as yours will not get an update to HDR as it is simply impossible to do without the correct hardware available.
However I dont see why the BBC cannot add UHD to the iPlayer for TVs such as yours in the future. HDR contains a set of metadata which will be interpreted if the TV can 'handle' it and simply ignored if not.
