Just bought a KDL-24W605A for the bedroom under the impression that it was a smart TV with access to BBC iplayer, having searched the TV features a hundred times I can't find it, and this includes on the SEN network.
I bought it from a nationwide retailer and thier website dictates that iplayer is available, and I've been told that the function is in the Apps store.. but where... I paid the higher price of this TV for this specific function, I'm getting really frustrated and don't want to end up with an expensive TV.. just to watch TV!
Regards
GH
Hi there
By all means, if you are not happy with the TV (or any product for that matter) take it back. However, its probably something minor - give Sony a buzz tomorrow and see if they can talk you through it.
Hi there
Can you try the following:
Thanks, before I get the TV out of the box and try this, can I confirm that the iplayer functions is 100% available on this model?
cheers
GH
Thanks, I've just tried the turn everything off for half an hour, still nothing, the playstation and DVD player have all the demand apps etc, talking to the shop who I bought if from, they are suprised as they have set this exact set up and are adamant it should have the same apps as the Sony DVD player, thier advice is to ring sony direct, if there's still no resolution, I'll be taking it back!
Also you may want to do a bit of quick testing before giving up.
If you check the network settings (I assume this option is available on your TV), is it getting an IP address from your home router? Do any other apps work or at least appear in your menu?
I have had issues like you mention previously and normally it's down to connectivity. You could confirm from the router side (if you can access it's admin menu) and check the TV is being assigned an IP.
