I've had a Sony Bravia KDL32CX523BU for two years, and it has worked well, until a couple of days ago, when the BBC iPlayer stopped working. When I click on the iPlayer app, I just see a spinning circle in the top right of the screen, and the iPlayer never loads. I can't even press any key on the remote control to return to the previous page, as the remote doesn't respond, and the only way to get the TV working again is to switch it off and on again at the mains.
All the other apps - YouTube, Demand 5, etc. - work fine.
Anyone else having this problem, or know a solution?
Thanks.
Hi there
Before hitting the panic button (yet), the BBC iPlayer Online is having issues:
http://iplayerhelp.external.bbc.co.uk/tv/connected/iPlayer_19072014
I know that this it the web-based version, but it might have stemmed further (who knows)
Hi there
What model TV do you have?
Hi there
The BBC have updated its website to the following:
Now, if it still not working, try the following
Hope this helps
I am having this problem too on a brand new & up to date KD-55XD9305 (June 2018) - the BBC iPlayer app will open & show available content but when I select something to watch it simply goes to a spinnig wheel before I recieve a 02110 error code.
I have tried resetting to factory settings, resetting my router & changing my IP address from DHCP to static (which results in my internet connecting disappearing on the TV entirely).
Does anyone have any other solutions to this problem? Seems entirely unacceptable that Sony are aware of these major problems with their 'smart' TV's but have done nothing to address them.
