Help please, Yesterday Iwas the first time I gave been unable to connect via my Sony Bravia tTV to iBBC Player
A couple of days ago - when watching regular TV - message boxes suggesting use of alternate HD channels pop up when, for instance I am watching BBC1. Since these appeared I am unable to connect via my Sony Bravia TV to iPlayer. All other internet connections are fine and it loads 5 on demand, Sky News, YouTube etc fine. The only fault is with iPlayer.
I have been through the Bravia systems and used Fadtory Reset and reconnected and checked my broadband wirless network - I use Virgin Media n- all of which do not solve the problem,
When trying to load t I get a fault screen stating that there may be Netwirk issues.
Any assistance/advice would be very gratefully recieved. Thank you.
exactly the same as us. I can access iplayer through my Mac!! but Sony need to sort this out NOW!!
Hello everyone.
Just to ensure that this is not lost in the "potential" flood of posts. The BBC and Sony are aware of this issue.
BBC:
Sony:
The iPlayer has not been working since thursday evening, it is unlikely its going to be fixed tonight.
I have exactly the same problem - yesterday iPlayer loaded ok on my Sony Bravia, today no. While all other Internet content loading fine. What's going on?
This is a link that I got in a reply to a tweet to Sony http://t.co/PaXFsGpAtg Not overly helpful but it looks like they're working on it. Seems their (Sony) BBC iplayer server is down which explains the lost connection bit
hi, same issue here with KDL32EX523 ..... i have noted that sony/bbc are aware and i just
hope that this issue is resolved asap...:smileyconfused:
Copied again below is the lastest info we have..
Latest Update we have - although not a solution
StartTheCar wrote:
Afternoon.
My colleagues in the Product Quality and Engineering team picked this up yesterday and are now looking into it.
As soon as I hear more I will let you know.
Lee.
Sony are aware as can been seen by their earlier post in this thread (copied above) & there is also an announcement on the BBC iPlayer site which might be worth bookmarking so you can keep an eye out for further updates..:smileywink:
Other than that we do not have any further information as soon as we know more we will update this thread..
Can I please suggest that rather then people posting additional replies with I also have the same problem etc. you simply click HERE which will take you to the first post in the thread & then just click on the Me Too button..
This will list your user name & save you the time of typing your post, etc..
Update:
Looks like a fix has been found because iPlayer is now loading but navagation within iPlayer is not yet working correctly yet but hopefully it should be soon..
