I bought my KDL-32EX301U in November 2010. Since then it has worked perfectly, up until an hour ago when the screen suddenly went like this:
http://i265.photobucket.com/albums/ii239/rogerbee/DuffTV_zpsa9e95c80.jpg
That is of course a freeze frame and the vertical ghosting also scrolls. I tried both unplugging and retuning but to no avail. Obviously the TV is long out of warranty, but, I was just wondering if there was anything I could do. I don't really want to fork out for another TV just now, but, if that has to be the case then so be it. Any input would be greatly appreciated
CHEERS!
Thanks for your reply,
It happened everywhere on everything, a reset couldn't save it. It's had a good innings I suppose, but nothing lasts forever.
A new TV it is then....
CHEERS!
Hi there
Yes, not a nice picture at all!
Is this happening on ALL inputs and devices connected (ie dvd/bluray player) or is it just Freeview? Can you test this out? If its just Freeview, I would suggest looking at your aerial cable (or aerial).
If its all other devices too, try doing a factory reset (a long shot to be honest). If that doesnt fix it......Well, you know the answer.
