Does anyone know the above as it's crucial to viewing video from external hard drives, especially if they have been used on a Mac?
The external HDD has to be formatted FAT32 before using with Bravia TV. I don't think there is any late model that support NTFS format.
You can use exFAT on many Sony TV's as well I think to get around the 4 GB limit.
http://lifehacker.com/5927185/use-the-exfat-file-system-and-never-format-your-external-drive-again
Many thanks etritd and Nielsen. I was wondering what exFAT was so I will try that and let you know.
My TV is working with FAT32 but with reduced picture size and the TV screen format option disabled in the USB conected mode. I have KDL40W5500 LCD bought in December 2009 so it will be interesting to see if the exFAT works.
I will post the result when I've tried.
Thanks again.:smileyhappy:
I've tried exFat and it doesn't work.
So it's FAT32 with a reduced screen image unless anyone knows how to get it up to full screen?
Ooh-sorry:smileyblush:. I guess a 4 year old TV is ancient.:smileyconfused:
But from your other post I would say your problem is more related to the restricted video format your TV supports on USB (mpg only). Mpg doesn't scale as well as ex. AVI.
I'll suggest to use home network instead with LAN cable, with ex. Homestream as DLNA server. That way you get more options on file formats. See sticker on Homestream.
Thanks for the Homestream idea, I'm also taking a look at the Apple TV box as my wife has an iPhone5 and an iPad.
Thanks again for your help.
