I have had my TV connected to a BDV-E370 for about 5 years and the ARC connection has always been fine with the sound from the TV and Tivo going through the sound system. While watching TV the other day the sound just stopped and the TV can no longer see the E370.
I have checked that the HDMI control is set to on for both and I've tried a factory reset but still no joy.
Any assistance will be much appriciated.
Thanks
T
Hi there
So to confirm
If you have any other devices connected to the tv can you unplug them and test ? Does this still fail?
If all this is the case, i can only assume a hardware failure on the port itself on either the TV or BDV - as i cannot think of any other reason or option to adjust. You may want to contact Sony Support to see if they have any other advice.
Hi there
At this moment in time, i would be looking at the HDMI cable. Can you try another HDMI cables - please remember to turn all equipment off first before unplugging/plugging in
Sorry forgot to mention I have already replaced the hdmi cable with a brand new one.
Hi there
So to confirm
Thank you for your help. It was the Tivo box causing the problem. I powered off and disconnected everything. I then just had the TV and Surround system connected and the TV recognised it, As soon as I connected the Tivo it would loose the connection. Rebooted the Tivo and everything is working perfectly.
It is so nice to have my surround sound back!
Thank you again for your help.
