How do I get more Apps on Sony Bravia 32WD75x?
I would suggest to use a Google Chromecast or Amazon Fire TV device to get more flexibility in terms of apps.
The TV itself does not allow the installation of apps.
What are a Google Chromecast and Amazon Fire TV device?.
I had this same problem... can't believe I made the mistake of buying the wrong tv. You can either buy a dongle like roko or google or amazon. Or you can connect your laptop via hdmi cable and view.
Good luck👍
How was I able to get them before without one of thease, but now I can't?.
I'm not sure, the app might have been terminated on your TV for example. But you can find all supported apps in this article by Sony.
