all the applications seems to have dissappeared on my sony bravia TV - any ideas how to get them back.
Hi there
Try turning TV and ISP router off from the power point on the wall. Leave off for a couple of minutes and switch everything back on again.
Also try Refreshing internet content on your TV.
Had this problem sometimes on mine KDL42W805, for example if the router is switched off when I turn on the tv and then I switch on the router. Seems like it doesn't recognize automatically that now the connection is avalaible: solved by going to the network menu and forced the TV to check the internet connection (I don't remember exactly the voice in the menu)
