I'm having the same issue, except I have an Ethernet cable. No connection to the Sony servers for anything is possible.
Yes, I can confirm as of early this morning all streaming apps working as normal at my place
Regards
Same - I seem to have lost all streaming apps on my sony tv - amazon, youtube and netflix are all down. Rebooted the cable modem, connection is fine when I've tested it and everthing else in the house is working fine. Netflix via the tv was working fine yesterday. Makes me think it is a problem with the sony server.
I cannot be sure right now as I am not at home but before I left all the installed Apps on Blu-ray Player BDP-S5200 were also unavailable. Internet checked out fine and Google web browser was working okay so this eliminates anry wireless signal issues. Did not have the time to check the TV. Somewhat pleased that this is a wider issue and not just a problem with my unit !
Please can someone post back if this is remedied.
Regards
Hello all
For everyone who is having troubles, can you please post back a few details
1: all apps
2: unable to authenticate on update internet content and unable to access Netflix and other apps
3: kdl-48w585b
4: of course
5: yes
6: have done at least 5 times
7: virgin
8: it's not an internal network issue,
And thank you for your help
Hi there
Ive separated this thread from the Netflix thread that this was all posted on. It appears this is a different issue than that of the original poster on the netflix thread.
PS: for others, please reply back to those questions as it might help to determine a cause if a wider issue is present.
Hi Quinnicus,
I wish I could help further but I have had to go out and earn the crust so to speak. I will answer what I had the time to check:
1. Multiple - Amazon, Youtube, Netflix. Demand 5, BBC iPlayer - basically the video apps
2. Checking network connection - then nothing. You can repeat this over and over until you are bored !
3. BDP-S5200 Blu-ray Player - did not have time to check other Sony devices
4. Yes
5. No but Web Browser did work on unit ??
6. Did not have time
7. TalkTalk
8. Set up network connection again on unit, checked internet status etc. and all registering okay with up to 97% signal strength
Hope this helps - for all I know it may be working again now !!
Regards
Same here - KDL-32W705c. Bought a couple of weeks ago and all streaming services (Amazon, BBCiplayer etc) set up and working.
Came to it today and got the message 'cannot connnect to this service' and the TV turning on almost instantly without the usual short delay with the SONY logo, almost like it was missing a part of the setup. You Tube and NFB Film sites still work.
All checks showed a good wi-fi connection and internet connection. Over the last few minutes some services are back but slow. This TV is fantastic but not impressed with backup services.
We have an XBOX-1 and this can connect to i-player, Amazon etc without problem.
All working now. I wonder if Sony are going to tell us what went wrong.
