I have been given a 3D Sony TV model KDL 40HX803 by a family member who is upgrading.
i need to get a power lead and not sure if I need one with an AC adapter or not?
i also need a table top stand but having difficulty finding one for this model do wondered if anything else might fit?
thanks in advance
regards Simon
@Plantphoto wrote:Hi Nic
thanks that’s good news as I’m sure I have a couple of leads that will work.Just need to find a stand that works and I’ll be good to go.
cheers Simon
Hi @Plantphoto
You could opt for a vesa table top stand. Just one example from hundreds https://www.amazon.co.uk/dp/B077P3SZGT/ref=cm_sw_em_r_mt_dp_U_aErlCb870KCEB
Hello @Plantphoto,
could you please upload an image of the power connector on the TV?
If I see which one it has I should be able to point you to the right cable
- Nic
Thanks for your help.
this is the power plug just not sure if need an ac adapter too.
regards Simon
Hello @Plantphoto,
thank you for getting back to me - your TV has an inbuild power supply, so you just need to get the 2 pin power cable that fits into the connector.
If you have as many devices as I have, you probably have one left over frfrom another device - if not you need to buy one.
- Nic
Hi Nic
cheers Simon
cheers Simon
Hi @Plantphoto
I did see that and thought it might work.
many thanks
simon
