can anybody help.
The app tray on my TV is for some reason empty. I can't load Amazon, now tv , you tube etc....
all settings are up to date, it is connected to the web, I have refreshed Internet content and still the tray is empty. Can anyone suggest a solution?
Switching off and on again doesn't work either.
is this a fault? Do I need to invoke the warranty?
Thanks
Hi there
The model of your tv - does it end in an A, B or a C?
If you have gone over things and all else fails - do a full factory reset of the tv.
I think it ends with b
Can you also ensure that you have the latest firmware installed:
And to do a factory reset:
http://pdf.crse.com/manuals/14HE468111/EN/c_gset_europeall_co_facset.html
Thanks. Give me a couple of days to get this tried and I'll come back to you. I really appreciate the speedy response.
