Does TMR-BR100 (3D transmitter) work with TDG-BR750 (3D glasses)?
Yes, should do..
for sure?
HI there
According to this manual : Here
The 3D transmitter works on Infrared (IR) signal
According to the TDG-BR750 manual : Here
The 3D glasses receive an IR signal from a transmitter
So both work in conjunction with each-other - A sender and a receiver. If you purchase a product over the internet you have a 7 day long distance selling legislation.
Hopefully that helps you
Cheers.
