I have got 60w855b and I want to know if TDG-BT400A glasses are suitable to watch 3d.
I will appreciate your help
regards
Hi there
Those 3D glasses will work with your TV as they are both for active 3D.
is that mean, TDG-BR250 glasses will work, as they are selling cheap on ebay.
cheers
Hi there
No, the TDG-BR250 will NOT work. This is because the BR250connects to a aTV via infra-red, whereas for your TV, it requires Bluetooth 3D glasses.
Which 3D glasses is best to use with any Device?? I am also looking for best one for mine TV
There are so many 3D glasses review with the sony web page. You can check the section of 3D glass on this website for the best glasses. If you want to check. i can share the link here.
