Hi
I'm thinking to buy additional 3D glasses for KDL-42W828B.
Which type should I buy.
Thanks
Edin
Thanks for quick reply
According to the manual : HERE - you will require the TDG-500P model of 3D glasses. P is for Passive.
Can be purchased : HERE if required.
