I've just got a Bravia 32WD756BU TV, which I am trying to connect to the WiFi in my accommodation. It is the sort where you connect to the unlocked WiFi, and on a laptop/phone are then prompted to login with a username and password. When connecting the TV to this network no option is then given to login, and hence I cannot make use of the WiFi.
Does anyone know how to make this sort of WiFi work with a Smart TV?
Cheers,
Seb
Hi Seb,
Have you updated to the latest firmware?
Best wishes,
M
Good afternoon,
Have you tried connecting your home wifi to the Sony using the WPD button on the side of the router?
It worked for me easily?
Colint106
