Hi
My Zylo's screen is now blank?!? I've taken the battery out and re-booted after a few minutes - the usual log on and graphics appear but then the screen goes blank instead of showing the usual main menu. Any ideas as to how I can resolve this?
Many thanks
Lisa
Can you not access your phone after it does this? Maybe you should check and see if there is new software for your device by using Sony Ericsson Update Service and see if this resolves your problem.
Thank you! Updates were available - downloaded and now working!
It might actually be your ribbon. If you can make calls and get sound as normal it usually means a repair to your phone and a replacement part
