Hi guys!
I really hope, that i will find an answer to my issue in here. So the issue is with ZOOM in browser in ICS. As all of may know, in GB we had an opportunity to ZOOM in or out by touching the bottom right side of the screen and after that appeared the small panel with +- buttons for zoom. Now, in ICS at least I don't have it ( maybe it's my particular problem) . I really confused because of it coz i often used this kind of zoom to read some kind of articles and it helped to reflow the text if text size was uncomfortable. With multitouch zoom text doesn't reflow...and this sucks to me.
So, does anybody have any idea-how to solve this problem? This is really important to me and i really like the default browser in NEO V.
If anybody have any idea i really would be appreciated!
Thanks!
what if you double tap?
With double tap it will make text onto fullscreen mode...i mean, all text can be readen, but if i would like to make it even larger? There is no way to make it with multitouch and have text reflow...only those +- buttons in GB were able to do this thing...
web browser > menu button > settings > accessibility > test scaling > set the desired value
I know about this...it's little bit different...i mean-if you need to change text size on the fly, i'm kinda doubtfull that you will go to those settings every time when you need to do this:) TBH-it's kinda uncomfortable..and actually, i just want to make sure that -+ zoom were disabled in ICS so i just calm down myself or i will go to service center to ask them reinstall GB back to my cellphone....anyway, thanks for the try to help me:)
