Hello, I have a rooted Xperia V phone.
Will it be a good idea if I install Xposed Framework ?
Is there any complications ?
You can read about it here
Thank you
I use Xposed so it depends on what you are wanting from it
Anytime
To use Xposed you need Root and Busybox installed then install the Xposed Framework and then you can install the modules
