Charge your phone for 30min > then repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
You will have to root your phone > partition your SD card > and use apps2sd/links2sd etc
Check this link, scroll down, you will find the process
