Please answer, I bought a xperia V one week ago and I found the surprise that when I have extended use of the camera in video mode or play a game at the bottom of the badge and the rear camera zone the temperature increases, although it is torelable but worries me ....
What is your diagnosis?
that's normal, not just with that phone but all smartphones in fact all electronics, the more you use them the hotter it will get, it won't overheat, if it gets too hot it will shut down by itself
Most importantly, do you have the latest firmware? If not, I would strongly urge you to do so. You can verify and/or check via PCC software.
As Member uliwooly has stated, there will be tolerable heat experienced with extended operation. Although I am not much of a gamer, I do experience such when playing Real Racing 3 for a few hours.
Thanks!!..
Anytime
