Hi there so I recently got my Xperia U ST25, and under settings it have a "tab" called Chinese Xperia-keyboard, but when I go to messaging I can't find the Chinese input.
Am I doing something wrong?
Or how do I enable it? Please help!
Regards
Yansen
Thread has been moved to correct communtiy by me
While typing, drag the notofication bar down and select the desired keyboard
If that doesn't helps then
Go to messaging app > new message > tap and hold on the white input tray > and select the input method
