Hi, I got an Xperia Tipo 2 weeks back from an authorized dealer. Now it’s touch not functioning well. I am not able to slide the screens and type message. I was done a factory reset and repair (Software) with PC companion. Is there any solution for this?:smileyconfused: Actually I am a big fan of Sony and I got many products from Sony. Now I feel very bad:smileycry:. Is it possible to get a new phone? Thank you…
take it to a Sony repair center
unrelated topic, if you have some time please check this thread
Today i went to service centre. It is a common problem. They installed touch screen caliberation. Now the problem solved. Thank you....
anytime
Install "TouchFWToolsAP_Sony-Ericsson-JDM-Platform.apk"
from
https://www.box.com/s/en766ervtijddpuygux9
after installation just open the app and click "calibrate"
100% it worked for my friend phone....
Hope it helps....
from
Hope it helps....
yes i had same prob for brand new tipo....
installed the appp n it works fine nowww...thankss a lott!!
http://www.benignblog.com/2012/12/how-to-fix-touchscreen-problems-of-sony.html
Even i had the same problem. But this fix works like heaven!!!
IMO, all your phone requires is just calibration. Check this http://www.josephcs.com/blog/fix-android-touchscreen-issues/
Download the calibration app and run once.
