Sorry to hear that you're having issues with the GPS.
I'm afraid it sounds like there's something wrong with your phone in this case. I tested it here and without assisted start i had a fix and 18 satellites in 15 seconds. Depending on your location your result may differ but it should not take that long.
Try dialing *#*#7378423#*#* and go to Service tests -> GPS -> Purge assistance data and see if that helps. Also try making a repair of the phones software using PC Companion if it doesn't help.
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
After resorting repairing option from kitkat4.4.2 , there is improvement in gps signal reception, now it is also showing GLONASS satellite status, but only in outdoors. Thank you.
Glad to hear that it works now
I have the same Gps problem and please tell more detail for fixing it.
What is "resorting repairing option from kitkat4.4.2"
Using a computer and PC Companion you can repair the software in the phone. install PC Companion in your computer and start it without connecting the phone and go to Support zone -> Software update -> repair phone but please note that this will delete all data in your phone.
Have been using Xperia since 7 months, it is generally found that GPS fixing is taking longer time (even with excellent AGPS network ), compared to other brands. What could have been the reason?
it work thank you
