I got an update for my xperia sp about android 4.1.2.
i had installed this update and now my xperia is not showing notification led blinking when i got a missed call.
and it is also not showing the led blinking with the colour which is more in picture when watching pictures.
plz fix this bug.
yup
its working now after i disabled stamina mode
exactly, well you probably figured it out not that stamina mode will disable that
