When I record video, it seems to stop once the file size has reached 3.8GB. I've changed from Full HD to 720p and even though it records for longer, it still stops once the video is 3.8GB in size. I figured it could be the memory card, so swapped that for a 16GB card, but the same thing happens.
Is this just a random thing or is there some way to get it to record videos over 3.8GB?
Hi All,
I don't know if this question is valid in this forum, but just wanted to know if there is any way to record the senseme slideshow in our album. If there is any, then please let me know.
Prayag, search the forum, if you find your answer it is good but if you don't then open a new thread. Posting in any irrelevant thread will not help you out.
Sure Thanks TJ.
Why is this always on top of the page?
its pinned post
look this have gray background..
this post seems important
FAT32 is not the only restriction for recording large videos, I remember I read somewhere that some DSLR cameras have a time limit when recording video or else they would be treated/taxed as Video cameras from the customs point of view. I think this only applies to some countries, but if it's not related to this exFat is the way to go or EXT4 if you're on Linux, idk hows the support for exFat in Mac
reset via recover
@andyessex wrote:When I record video, it seems to stop once the file size has reached 3.8GB. I've changed from Full HD to 720p and even though it records for longer, it still stops once the video is 3.8GB in size. I figured it could be the memory card, so swapped that for a 16GB card, but the same thing happens.
