Hi, I am thinking of buying the Sony Xperia SP.
1. Do you know if the Smartphone will work in Russia without problems concerning the covered frequencies.
2. Does Sony have a worldwide guarantee? How long is the guarantee period?
3. Does the phone have a standard simcard slot?
Regards Bernhard
It has a micro SIM slot.
Should work in Russia - they sell them there after all.
One year warranty on mine.
@blackbox wrote:It has a micro SIM slot.
It supports Russia basband..so you can use it
