My lacd light only works when i take a call and recieve a call..it doesnt lit when i have a missed call or a sms. i have the xperia theme on for missed calls i have put yellow and for unread sms white colur all others are standerd..
y?
No,LED notification does not work during STAMINA MODE ON.
1.During Stamina Mode ON,you will NOT receive any notifications via LED Strip.But you will be notified if your battery reaches 14% and below(will blink red very fast).
2.It depends.If you set Incoming calls to BLUE.The LED Strip will LIGHT up in BLUE even with Stamina Mode ON(also works with Incoming SMS).In other cases,for example an unread SMS,you set the colour to RED,the LED Strip will NOT light up when Stamina Mode ON.The unread SMS case also implies in Missed Calls,app notification and Alarm.(So they will ONLY work if you switch OFF Stamina Mode.
3.During charging,the charger will automatically switch OFF Stamina Mode.So you will receive notifications via LED Strip for all cases(Incoming calls,Missed Calls,Incoming SMS,Unread SMS and so on).But soon after you unplug your phone from charger,it will automatically turn back ON Stamina Mode(it only happens,if you switch ON Stamina Mode even before charging)
If your LED Strip lights up for Walkman and Album app,that means your phone is okay...
And can i ask you a question?Where are you from?
Could you elaborate? is it the Screen that doesn't turn on or is it the notification LED?
the lcd notification light
Does the led notification light work in stamina mode? ( thats when the phone is sleeping with stamina mode on)
please if some one knows tell me how this led notification light behaves when i have a unattended call or a sms.
1.when will the notification start? ( as soon as the call or sma came? or else sometimes after the call or sms unattended?)
2.will it stay on in the colour i choosed, or blink untill i attend to it?
3.will it work while my phone is charging?
My led notification light is working with music and pictures and incoming and outgoing calls but not for unattened calls or sms. need help....
Thanks bro....
I am from sri lanka
