when recodring video at 1080p the phone is getting heated to 35-40 degree celsius and this also happening while charing only.....is it normal ? plz reply.....
If the temperature of the battery reaches 50-55 it needs a check at a sony service.
i've just done the latest firmware update and its apparently meant to prevent overheating of the battery and it hasn't i'm getting worried now aswell as it seems to be effeccting my memory card and making it corrupt everytime it overheats
like most people its hitting 50c on charge and between 45c and 50c on wifi usage anyway to help sort out this issue?
Remove the micro SD and put it back.See if media server still acts up.
