So i was about to test the gyroscope and accelerometer calibration at Test Service.But then it said "This device does not support this function"
Which version of Xperia SP do you have ?
On my C5303 Sensor List confirms, and shows live graphs for them, both sensors you're talking about :smileysmileywink:
I suspect this only means that the service menu can't calibrate them. The service menu may have options that are not intended for the model in question as it's used in several models.
Try downloading an app or game that uses these sensors to see if they work properly like Temple Run or simply turn the phone when in Chrome and see if the displays switches to horizontal.
Hah!Just as you said!Chrome did switches to horizontal display.Not even a flaw is found of this phone.Thanks!
Jarda:My Xperia is C5303 LTE Version,Not rooted.Firmware newest .254
