I did a backup and i wanted to refresh the software. The Sony PC Companion gave me error messages time after time so i unpluged my phone. It does not turn on, the PC fresher cant help. I tried the off button many times, it just vibrate and nothing happens. If i plug it in the wall adapter the notification led slowly flashing with green colour. The battery was about 70%. Any idea?
the battery wasn't discharged and i charged it but nothing happens. the green light is still flashing.
When i push the sleep button the led flash a very quick and nothing
try to simulate taking the battery out by using the off button depress it with a pencil or hair pin holding it down for about 8 secs , let it vibrate 3 times then try to restart the device
nothing.... just the fleshing gree light
it look i have to 😕
Ey guys i made it work! Restarted my computer, plugged the USB in the back of the computer, started the "reparation of the phone" without plugging the cabel into the phone. I just plugged the pfone in when it started to prepare the computer, and it worked. It reset the system.
You repaired with pc companion or sony update service?It is working now?
