Hi.
Just bought a brand new Xperia SP on EE pay-as-you-go. I want to ask about the camera on the phone.
Is there a burst mode feature in the camera? The iPhone 5/5C has specs equal if not lower than the SP and yet the OS was capable of "handling" burst mode in some way.
Please advice. Thanks.
For the burst mode,you need to keep the camera button pressed for some time,it will automatically shot.
But i thought a burst mode should be "enabled" first under the cmaera settings?
You can search through the options,I do not own SP.Does the suggestion I gave you work?
Yup i tried it but for some reason it only took 2 shots.
I can only find Sports option under Scene Selection. I cannot seem to find a proper burst mode option.
Go to settings-apps-all,there should be an app unlimited burst mode or something like that.But I have no idea how to use it,I only know of it:smileymrgreen:
Search the google play,find what you think suits you and is compatible with the phone.
Xperia Sp's camera doesn't support burst mode. There is a burst mode app in the .284 system apps folder. Probably leftover code from the Xperia Z build (which the SP is based on, they wouldn't rewrite all the code) that was disabled because the camera wouldn't support it. Though the next update(4.3) may support that.
Don't forget to give kudos..
