Is it possible to play music from my Xperia Sp via Bluetooth to my Samsung Bluetooth enabled soundbar?
If so, how do I do it, I can't see it on my phone or in the manual?
Many thanks!
It should not be a problem. You just have to pair the devices with each other. In your Xperia phone, go to settings > Bluetooth > activate Bluetooth > search for devices.
Make sure that you have your soundbar in 'pairing mode' or 'searchable mode', For more information, check the manual for the soundbar.
Can you confirm me the model number of your Sound Bar so that i can provide more accurate information...??
Perhaps i found this HW-E550 Sound Bar from samsung try the methods as described..check this link
http://www.samsung.com/us/support/howtoguide/N0000463/9384/93213/
To pair your device to the Sound bar using Bluetooth, follow the steps below.
then go to your phone Menu > Setting > Bluetooth (enable it ) > click on search button and try pairing
If it ask for any password enter 0000
keep posted after trying..!:smileysmileythumbsup:
Thanks santam. Both solutions arrived at the same time, You should share the honours!
