Try settings-apps-all-smart connect and sound enhancements,force stop and clear data.Restart.
Check the 3.5mm input for any dirt and try to clean it.
Strange,keep us updated. If it happens again,report here.
Have you tried the repair with PC companion?
If that does not help,you need to stop by a sony service.
