Hi everyone,
I've bought Sony Xperia S, very nice device,
But I have a problem that makes me really sad,
My xperia s refuse to accept any micro sim card, I insert one after another from different operators in my country "Egypt" but all don't work,
When put the micro sim, the phone feels it and do a restart to be prepared to use the newly inserted micro sim buy after restart it keeps telling me " no sim card" despite the micro sim in correctly cut & inserted,
I've tried software update & repair , also many different micro sims, but useless
Can you help me with that !!!?
okay...
This is what I'm going to do ,...
Thanks alot for your help, ... Good Luck
lets double check if it's locked to a network
open the phone app and dial
*#*#7378423#*#*
Service info > SIM lock
No worries--hope you get it sorted.
It sounds like your handset Sony Xperis S is network restricted to carriers.. you can get this removed using codes.. you can purchase such codes from any vendors online like Mobileunlocksolutions.com
You have made so far 16 posts some of which are in threads more than a year old and in everyone you are advertising - This is against the rules
