Settings > more > mobile networks > Network mode > GSM only
Don't forget to give Kudos
Its not working in that way because, there is no option to select the downgragded networ (2G). There's an option to select only 3G. Another thing, I ca select 2G network forcefully by selecting Mobile network, but it automatically goess to 3G which I dont want. Please anyone give me a solution that how I can go and fix my network into 2G.
Manna
Please mail me if there's any solution
that's for me too even i tried to downgrade my andriod to 2.3 ... 4.0 not effects please help us
Facing the same problem
tried almost everything
even sony center couldn't resolve
this problem is very irritating whenever i remain at villege level where there is still 2g towers only...
plz sony do something
this is frustating and irriting...otherwise have to replace this costly handset......
I also have the same problem. Earlier, I thought Idea has this issue. Now, am using Vodafne and facing the same issue. Really having a tough time with this phone. Probably, will have to switch over to other phoe, if the problem exists longer.
Dear Sony,
Does this problem have a solution or do I have to brick the phone
Same problem with my z5 too. It connects only with 3g. It dont connect with 4g and 2g at all. Also it doesnt connects with gprs. In naugat the problm persist. Then i downgraded to marshmallo by sony campanion s/w but it did help me at all. Thinking of swicthing fone
