Please anyone knows how to tell when was my Xperia S or any other Xperia manufactured?.. The Day/Month..etc!!!
Thanks
remove the back cover and look for 12W10 (as an example) that will be 2012 week 10
unrelated topic, if you have some time please check this thread
mine is 12W43.... so its October 2012
thanks for the helpful and great info... I learned something new now
thanks a lot
what about the xperia Z?
You can find it on bottom side where it written made and serial number...
