I've seen that the Xperia S has light ambient sensor, but i cant find the configuration to enable auto screen brightness.
Any idea how can i enable it?
its work fine with when i get calles but dont work and dont have auto screen brightness option
can anyone help
Why not read the forum posts on XDA from where you copied and pasted the question from
