i want to throw this question to all the owners of the new Xperia S? it would be lovely and highly appreiciate if you can provide personal feedback of the quality of photo. Thanks thanks thanks...
the problem remain
Even engadget share more or less my view on the new Xperias
http://www.engadget.com/2012/03/08/sony-xperia-s-review/
"Could the Xperia S be your first Sony-branded phone? It you're all about media consumption, and if you're prepared to wait while Sony makes its cloud-based platforms more coherent, then the Xperia S is a great device. The display and the speaker are absorbing and addictive. The battery life is excellent, the processor is a good fit and the absence of expandable storage shouldn't weigh too heavily if you get the 32GB option.
On the other hand, if you make more varied demands of your smartphone -- like excellent build quality, pocket-friendly slimness or photos you can enlarge -- then things get more complicated. US pricing has yet to be announced, but the 32GB version of the Xperia S is going for upwards of £430 ($680) SIM-free in the UK, or £370 pay-as-you-go on the Three network. Similar money could fetch you a legendary all-rounder like the Galaxy S II, or stretch to a 16GB Galaxy Nexus with an HD screen and better build quality, or -- very soon -- an HTC One S, which promises a cutting-edge Qualcomm S4 processor and abetter camera. When sized up against a long rubric of criteria, rather than just its entertainment credentials, there's little to make the Xperia S a compelling purchase."
"Previous Xperias, such as the Neo, suffered from excessive image compression, and that's still unfortunately an issue with the Xperia S. There's no option to change the JPEG settings to create bigger, prettier files comparable to what you'd get on the Galaxy S II or iPhone 4. The default compression has improved considerably since the Neo, with 12-megapixel stills averaging a file size of 3MB, but that's still not enough."
i believe it is suffering from compression ... though i am not a Xperia S user
the problem remain
https://plus.google.com/117586446271921149656/posts/jgJgbxSyLEX
Sony Xperia - +Alexandre Bote Tronchoni Thanks for the comment and the compression of images is something we are in discussion in our development teams but today do not have a more firm answer. - Nik
Still not good enough, we need solutions
Install UCAM, You can choose the compression rate for the photo...(or not compresion) So you get a better photo. I use it in my Xperia neo and I get bigger photos and bigger quality...from 1 MB of photo to 5 mb of photo!!!!
Incredible....such a Software issue!!!!
I'll check it out, what do you guys think of this?
Xperia S picture quality, the pictures look amazing on the S's screen but washed out on a regular LCD/LED or HD TV/Screen
it's too slow and it's UI its not that great
