um using ICS 4.04 on my xperia RAY.......i am facing some battery charging problem.....When connected to PC, the phone gets detected -> but it doesnt get charged bt the battery icon at the top will indicate that its getting charged but the battery bar is not completing is charging cycle similary When connected to power-plug, phone shows its charged 70%, bt after charging 6h , it remains in 70%............but when i restart my phone then phone shows me that , phone charged 100%.........& when i charged my phone it shows red light , after full charged it shoes green but mt battery bar does not shows full(agter restaring phone battery bar shows full)..............why the battery bar doesnt shows full without restarting phone????
SUS also said software upto date !!!
i downgrade to ICS 4.04 to 2.3.4........now battery is working
You can now stay on GB or upgrade to the ICS.
The problem would not recur.
I am Facing Same Problem on my xperia ray St18i Repaired Phone Software But Not Working
Mr Sajid how did u resolve your problem? can you please explain??
please tell me what charger shall i purchase for sony ericisson xperia ray( charger number)??
