Is it possible ?
(I really mean *FM* radio, and not 'internet streaming' radio)
Ideally, a recording application that allows you to select the sound source (fm radio, mic, call, internet streaming, etc.) would be perfect, but I didn't find such a thing. Any suggestion ?
haven't insalled router at my home!! so maximum time I used my network 1!! and I also dont use to hear fm all the time only at home.. then give it to ur mom she will love it !!!:P
give the phone.??
well she uses a moto rokr and it also have music recognition
then it's fine!! don't have to give arc!!!!!;)
Thanks... good job, guys (slimshaddy & sanatm) !
It was the first time I was manually installing an app...
It's really great !
(only records .wav files, not directly .mp3, but that's already very cool !)
I hope I correctly marked your answers (I'm relatively "new" here...).
By the way, if ever you have another "secret" app to "only turn off GSM" (cf. this thread: http://talk.sonyericsson.com/message/154576), don't hesitate to tell me !
you done all correct
aah i can't think of that . let sanatm think
thanks!! yeah u've marked ri8!! for ur other question I got a silly answer but it should work I guess!! but u need to tell me what network ur using I mean GSM/CDMA??
hey @slim i've already got an idea!!!
then share it already.... whatever you have
posting in that thread!! check out:-P
posted!!!
