I had xperia pro a month ago. about a week ago pc companion told me that there is a new update available. when i tried to update everyday there is error updating. what should i do to get my phone's software updated??? i read more and more but no result
PLZ Help
or use this
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
turn on your wifi then -> settings -> about phone -> software update
if there's an update it will show here
or use this
i did that and it tells up to date i checked build no. and it is 4.0.2.A.0.62
and the available update is 4.1.B.0.431
same problem!!!
so you have 2.3.4 build number 4.0.2.A.0.62 and it says you are up to date?
is your SI number on the list?
