My Xperia Pro seems to have some light scratches on the screen and this is strange since I never had problems with any of my phones that had a scratch resistant glass.
I read on the internet somewhere (i guess on gsmarena) that the Xperia PRO have a very thin screen protector on the screen (not the standard one, but a very thin one). And they were sugesting to remove it after it get scratched.
Is this true?
Andrei
Hi, frankly, I would just leave it. I believe your Xperia Pro does have a factory applied screen protector, have a closer look at the corner of the screen.
that's only true for the Active, since it has gorilla glass.
acttive use dragon tail not gorrila glass
Hmmmm .... new batch with new specification? :smileymischief:
:smileygrin:
i read it somewhere i dont remember ...:smileysilly:
Search and read again.
Ok, i searched it, here it is:
http://www.gsmarena.com/sony_ericsson_xperia_pro-reviews-3779p3.php#2602986
the guy complaining about the same problem i have: JeanPierre at 2012-01-16 02:34
The answer with the thin protector was from Green-UZB at 2012-01-19 20:48
well here it is .
http://talk.sonyericsson.com/thread/29144
i am saying the same thing der also
.. but the main thing is that Samuel-SEAnswers also agrees with me :smileygrin:
so i guess i am right ?
