I got an Xperia Pro a few months ago. A few days ago, I decided to update it to ICS, but I read online that the ICS used to change the QWERTY keyboard to AZERTY. Has that problem been fixed yet? I want to make sure that it has been fixed before I update my phone. When I connect my phone to my computer, the PCC says that 4.1.B.0.587 update is available. Is that the update in which the AZERTY problem has been fixed?
As far as I know this issue has been solved so yes, you can update. If you experience any further issues or have any questions regarding update procedure, please get back to me.
Thanks Samuel.
