Hi!!
i am using airtel gsm on my xperia pro...
i have a xperia pro model..
i was using 3g for about 4-5 months...and the status on the right top of screen was coming as "3g" or "H".
I was able to call somebody by speaker and chat through facebook at the same time..during any call my net wasnt get disconnected.
but somedays before i saw the full tower of network but no service avialable...i cud not able to call..message...or anything throught my phone.
then i went to mobile network setting and change the option from "WCDMA only" to "GSM only"...
after that i was able to get the service ...and everything is working fine...
BUT the status which i was getting intially as "3g" or "H" ....now i am getting "E"......and now when i try to call somebody or if i get a call then my net automatically get disconnected and when i cut the call ..the net resumes by itselfs...
plz help me with this...how am i able to get back to the previous one...where i can make call and use internet at the same time...
you need WCDMA preferred otherwise you are NOT going to get 3G nor H, as GSM only it's Edge = E = 2G
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
i did tht...and restarted it..
now i m getting 3g or h..
thanks a lot...:)
anytime
