is there any way to turn this off. i have a heart condition and im sick to death of that damn alert noise. it makes me jump everytime it goes off, and it normally goes off when im playing a game so the phone is closer to my face than normal.
None that I am aware of, however I will forward this information on for you.
I don't know of a way of turning the low battery alert sound separately from the other phone sounds. You could perhaps keep your phone on a charger when playing games, where possible, but I know it is a mobile phone and therefore you might not always be near a socket, of course...
like you said. its not always possible. i even thought about deleting the sound file for the alert but have no idea where it is.
I can clarify that there is no way to remove this warning message, as it is a core component to the handset operating system.
I am sorry for the inconvenience.
thanks anyway. any plans to address this in future updates?
I'm getting low battery warnings every 2 seconds on my Z3 compact. It's annoying, and it's draining my battery!
