Does anybody knows how to import a song from walkman as calling sound?
I could easily do it before the upgrade into JB.
Thanks
You want to do it while the song is playing?You can go to my music,go to the specific song,tap longer on it and go to the last option called set as ringtone.
Thank you very much for your response which helped me to sort it out.
Thanks again
Glad to help.
