its a bug .. disable your default notification sound to silent then all your tones will ring withoug problem ..
we wont get major update like 4.2, 4.3 or 4.4 but may get a bug fix update only !!
Yes,I support the idea of a bug fix update,but no 4.2 or 4.3.
Did you repair phone software?
Are you using Viber or whatsapp?
