Only that button makes you trouble?Why cannot you go to a sony service just for a quick check?
It could be air bubble issue,do you have small air bubbles in your transparent bar?Maybe you should take the phone to a sony center.
If you do not see any problem,try to force restart the phone(power button+vol up until the phone vibrates).See if the button is ok.
I do understand your reluctance however I don’t really see another way around this than having it assessed.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
